intake for radical 305( LO3) build-up?
Old Jul 29, 2000 | 08:11 PM
motley400RS's Avatar
Well , as you all know ( probbly not PABLO though, he was left fumbling with the weel at the GREEN light ) I decided to get jumping on a radical 305(l03) project . Seeing how everyone is always up to dis them , I am destined to prove you wrong ! This is my old 305 from about 2 years ago ( it has been on the garrage floor ever scince). I will be aiming for only the most outrageous specs , I would like some educated opinions ,geared twards my goal , on what kingd of intake I should treat it to ---MPFI , TPFI, DUALCARB W/BLOWER ---let me know . I am looking for 11.2 : 1 copression ratio , 40cc heads and so on . I am mostly trying to piece together what parts to use , and doing the math, right now.Nothing is in stone yet , but soon enough I will be able to blueprint it and then be able to pass a (hopefuly) killer setup to All you people with those 305(lo3's) out there ......later
Old Jul 29, 2000 | 11:31 PM
firebird305's Avatar
COOL!!!
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,Hopeing to run good times when i FINEALLY do get to the track!!
Old Jul 30, 2000 | 12:40 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
40cc heads?
Old Jul 30, 2000 | 04:15 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Old Jul 30, 2000 | 12:08 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's funny:0)
Old Jul 31, 2000 | 12:20 PM
well , mabie 40cc is a bit SMALL , you get the idea .HA - HA - HA , pablo you must have a real winner of a Pontiac there , seems to me you can't cope w/ the idea that every time I post something that has to do with camaros , you put your 2 cents in .Sorry mommy and daddy wouldn't give you more money for a better car . I have seen your site , and that car .....HOPELESS . Hey , do this , take a big sledge hammer and total it --then buy a camaro w/ LT4 or equivalent and then and only then can you even begin to diss my car .
Old Jul 31, 2000 | 02:19 PM
Jester90RS
Guest
Posts: n/a
Tunnel Ram with dual Dominators, the only way to go
Old Jul 31, 2000 | 02:58 PM
hey , that tunnle ram is nice , but I was hoping to get a reation from this pablo idiot.....
later
Old Jul 31, 2000 | 04:54 PM
Box of Rocks's Avatar
Originally posted by Pablo:
Pablo,
I really like the MOFW response.
MOFW = Man of Few words.
Simple, to-the-point, no nonsense reply.
I guess his budget is "unlimited" ?
Jeeeezzz......
BOR
Old Aug 1, 2000 | 07:04 AM
Money isn't a big concern here, PABLO .Besides , I went to college and got schooling and now make damn good money rather than "pimping it out " ha ha -- I don't have to pimp girls just *** to me al the time ...later
Old Aug 1, 2000 | 07:10 AM
Eggplant Jeff's Avatar
I'll watch Pablo's buildup sooner than yours... :-). I think my budget is a lot closer to his.
Old Aug 1, 2000 | 07:18 PM
Tab92bird's Avatar
Umm...you do realize that once you swap the heads, intake, exhaust and cam (which I'm sure you'll have to do for a "radical" engine), it won't really be an LO3 at all.
On another note, do us all a favor and save the space on this board for non-BS posts.
Brandon
Old Aug 1, 2000 | 08:50 PM
Voyager Project's Avatar
If I were to build up a 305 I would do this in this order.
1) take block to macine shop have it completly stripped and have it ported and polished.
2) buy a 305 stroker kit for the **** from PAW. then it goes up to a 337 or something like that with balanced flex plate.
3) Get an entire edelbrok power package: idle to 5500 RPM, with high flow MPFI.
4) Excel ignition.
5) Edelbrok headers, and high flow cat, and cat back system.
This the general idea behind the engin concept I call the RWC1.
Old Aug 1, 2000 | 09:14 PM
ede's Avatar
ede
well thanks guys i use to have a BS meter but it's pegged now and the needle's bent.
ICON Motorsports
Jake_92RS
Jan 28, 2020 10:37 PM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
