Preformance Chip
Old Aug 1, 2000 | 03:53 PM
Phil.B's Avatar
Preformance Chip
I have a 87 ROC 5.7 TPI a friend has a Preformance Chip from a 88 ROC 5.7 TPI. Can I use it or at least try it out with out causing any problems.
87 ROC 5.7 TPI K&N's gutted air boxes, Hooker Cat Bak system, 160 t-stat, Thottle body by-pass.
Old Aug 1, 2000 | 07:42 PM
Lounge Lizard 6's Avatar
There weren't any major diff between '87 and '88 so it won't hurt to give it a try.
Mike
'90 IROC, 5-speed, ZZ4, & Trick Flows
Old Aug 1, 2000 | 09:27 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
It may throw a code since it was setup for your ecm.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
