Evaporator Core Problems
Old Oct 12, 2019 | 04:56 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
I am hooking up my AC now that my swap is done and I am having some problems with the Evaporator Core and Expansion Valve. I know it goes into the small line at the bottom of the Evaporator but the core that I am using, Four Seasons 54537 does not seem to fit a valve. I put a regular valve in there and it sticks out about a inch. Am I doing something wrong? Other research says to use the 96 Crown Vic expansion valve with I need to get.
Old Oct 12, 2019 | 05:35 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
Re: Evaporator Core Problems
OK, I figured it out. It appears I was installing the expansion valve in backwards. I noticed the arrow that points into the evaporator. It seems to fit very tight when its almost in but I assume a little oil will help it seat. This is what happens when you take something apart a long time ago and forget how it goes back together.
yevgenievich
May 7, 2018 09:35 PM
25THRSS
Jul 17, 2014 10:28 PM
LarryD
Sep 9, 2012 11:04 PM
frogmanjohn
Oct 19, 2005 09:23 PM
88NOSTA
Aug 13, 2002 03:20 PM
