Coolant Being Sprayed Around Engine Bay. Water Pump Failling?
Old Nov 1, 2019 | 11:20 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So I am losing coolant and have some sort of coolant leak from the front of my car. Early today when I started my car and popped the hood, coolant was being sprayed all around the engine bay. My guess it was hitting the belts and being shot around. Could the water pump be failing? It was replaced two years ago and it's from NAPA. Could it have failed already?
Old Nov 1, 2019 | 11:23 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Coolant Being Sprayed Around Engine Bay. Water Pump Failling?
Pinhole in radiator hose ? Water pump gasket ? pinhole in heater hoses ?
Old Nov 1, 2019 | 11:34 PM
Engine: LB9 305 TPI
Would a pinhole in the lower radiator hose cause coolant to spray everywhere? Same with the heater hoses? It only sprays some of the time and when it does it looks like it's spraying from every direction.
Old Nov 2, 2019 | 02:07 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Is it sprayed up upon the hood above the accessory drive belt? If so my speculation would be the water pump has failed and it’s coming from the weep hole. Look in the area of that you might stumble on the source that way.
Old Nov 2, 2019 | 11:28 AM
Engine: LB9 305 TPI
When I last watched it spray, it looked like it was mostly lower in the belt and it was barely reaching the top of the radiator. Also when I first shut the car off a ton of coolant dripped but I couldn't pinpoint exactly where it was dripping from.
I was planning on flushing the coolant anyway, I already brought everything to do it. When I'm going to buy a lower radiator hose and replace it. If the problem isn't fixed I guess it means it's the waterpump.
Old Nov 2, 2019 | 12:31 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
The heater diverter valves fail often. Had one go on me on the freeway. Pop goes all the coolant.
Old Nov 11, 2019 | 05:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Loosing His Cool
It does sound like the water pump.
A way to stop the dripping in your garage or driveway until you can replace it is to bump the starter.
You will find a position which will stop it from coming out of the weep hole.
HappyRacing!
Headlight Goofs By Designers #15; TOO HIGH: Pickup truck headlights are mounted too high therefore they are not aimed onto the road, they are aimed into your eyes.
IROCmenace
Apr 18, 2012 10:57 PM
tradeforcash@be
Jun 12, 2009 12:48 PM
91greenbird
Jun 3, 2006 09:22 AM
rezinn
Jul 15, 2001 12:28 AM
Bill 88TA
Sep 27, 2000 03:47 PM
