i think my water pump is bad
Old Jun 1, 2006 | 09:42 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Well i was working on my iroc and fixed the idle problem it was having and while it was running i kept seeing a mist of coolant spraying all over my engine pay it looks like it was leaking somewere and hitting the belts causing it to fly up and splatter. It wasnt leaking from any hoses or the radiator. I looked under the car and there was a puddle of coolant right under the pulleys and my smog pump was covered in coolant. I have heard when a water pump is going bad coolant will leak out of the pump and cause this. So is my water pump shot?
Old Jun 1, 2006 | 09:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It could be, watch for drips coming from the weep hole on the bottom of the pump.
Old Jun 1, 2006 | 09:53 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what else could it be, only thing ive done cooling wise is tb coolant bypass
Old Jun 2, 2006 | 12:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A leaking hose or fitting, or a freeze plug.
Old Jun 2, 2006 | 11:25 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
its not a freeze plug because its coming from the front of the engine. The owner before the owner i bought it from said something about the water pump was junk so im pretty sure its the water pump just need alittle reinsurance.
Old Jun 3, 2006 | 09:22 AM
ChrisColeman's Avatar
Yeah, When the bearings in the pump go out of spec (wear out) it allows the pump to seep out coolant. Start the car and go under it, you can probably see the coolant seep out the little whole on the bottom of the pump. It is made to do this.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
Newguy91rs
Aug 7, 2015 09:51 PM
