Fan Mounting to Radiator
Old Apr 30, 2020 | 02:13 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Hi all. I'm trying to find the easiest way to mount these Malibu fans to this 3rd gen radiator for my ls swap... the radiator doesn't have the the factory clips that holds the fans. Any suggestions?
Old Apr 30, 2020 | 08:53 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Re: Fan Mounting to Radiator
I cut the upper and lower flanges off of the original fan shroud and bonded them to a GTO fan assembly. It fits perfectly and bolts on like the original single fan. I was looking for the pictures that I took, but I seem to have lost them.
Old Apr 30, 2020 | 09:52 PM
soloc4's Avatar
I found one.
If you look closely, you can see that I riveted some L- brackets in place for additional support while the 3M 8115 structure bond cured.
MoMoney
May 15, 2019 06:47 AM
miche25
Apr 22, 2019 03:40 PM
8587ta
Nov 16, 2016 04:29 PM
Firebird1984
Mar 31, 2007 02:32 AM
slowmaro13
Exterior Parts Wanted
Aug 20, 2006 04:13 PM
