Aluminum radiator and fan/shroud combo recommendations
Old Jul 26, 2020 | 11:49 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Anyone have any fan/rad combos they have ran? I have been in the market to replace my stock plastic radiator and taurus fan with an aluminum one and shroud combo.
Old Jul 27, 2020 | 10:13 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Re: Aluminum radiator and fan/shroud combo recommendations
The 4th gen fans fit with little trimming and you can find them used. I picked up a set of 98-2002 fans for about $40 from a pull a part. Fit well with a little trimming. You will need to add a second fan circuit.
Old Jul 27, 2020 | 11:34 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
There's a bunch of them at Summit. Should drop right in.
I would probably go for this one if I was going to replace everything:
https://www.summitracing.com/parts/r...t/model/camaro
Old Aug 10, 2020 | 03:49 PM
FAST LiFE's Avatar
Maybe it's just my but I've never had an aftermarket fan last as long as an OEM fan. I've tried Spal and Flex-a-lite. I've never had cooling issues with the stock 2 row, even with my last 406. I did change out fans to 4th gen OEM LS fans.
mxxdude
Jan 19, 2011 04:42 PM
billybob6110
Feb 12, 2009 06:30 PM
QuickStyle
Oct 3, 2008 02:53 PM
SaintedCorrupt
Oct 5, 2005 03:08 AM
