Lower rad hose, no spring
Old Sep 7, 2020 | 10:45 PM
caddyescalade's Avatar
Hello all, I’m having some cooling issues, especially after higher rpm driving. I’m wondering if my lower rad hose is collapsing under higher rpm. Mine does not have a spring. Is there a way I can tell if this is happening? Would you see it collapse while revving without a load?
thanks
Old Sep 8, 2020 | 06:45 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Lower rad hose, no spring
None of them have a spring on thirdgens. I just found this out a short time ago...
Old Sep 8, 2020 | 09:00 AM
Interesting, I’ve read about the requirement of this spring from a few sources while I’ve been researching cooling.
Old Sep 8, 2020 | 09:30 AM
T.L.'s Avatar
Apparently, GM did not see it as a requirement...
Thirdgens are notorious for running hot. Check the rest of the cooling system components for the cause of your problem...
Old Sep 8, 2020 | 10:17 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
No. Spring not needed. Entire system is at 16 psi. You can check. Rev engine at throttle while watching lower radiator hose. It will not flatten out. If it does, you have that issue but it is caused by something else.
lizardkng
Oct 5, 2012 12:43 PM
84transamdude
Jul 10, 2011 08:07 PM
xX89RSXx
Apr 25, 2010 01:38 AM
Jason92Z
May 9, 2004 10:53 AM
RMK
Nov 16, 2002 01:22 PM
