Car Running at 200-220 On the Highway.
Old Sep 10, 2020 | 03:59 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I have a 1986 Camaro IROC Z TPI. With the AC off after my car warms up the temperture gets up to 200-220 on the highway. The car has the air dam, the lower radiator hose was replaced a year ago and it's not collapsing, 180* thermostat was installed in March, water pump is 4 years old and runs like a charm, no noise, no weeping, no coolant leaks anywhere, no bubbles, rad cap is new since March and original ACDelco.
It started doing this about a month ago. I don't know if that's because for the last month the temperature has been 95*F with the heat index close to 110*F? Any ideas?
Old Sep 10, 2020 | 04:07 PM
ULTM8Z's Avatar
Re: Car Running at 200-220 On the Highway.
Maybe wait until the weather cools down and see if this setup runs cooler.
hotter weather will reduce the ability of radiator to dissipate heat to the air.
You said this high running temp started within the last month, but your setup has existed in its current state since March.
Old Sep 10, 2020 | 05:12 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Make sure your torque converter is locking up at freeway speed in 4th gear if not it will add more heat to the radiator.
Old Sep 10, 2020 | 05:39 PM
Is this a problem? If so, how?
Old Sep 10, 2020 | 06:01 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
My stock 87 5.7 runs ~170 according to the stock gauge, only in town/very slow driving does it go to 220 then the secondary fans kicks on. I don't think 200-220 is 'damage level' hot but seems warmer than I'd expect for highway only. I don't have a magic solution for you, sounds like you have checked the basics. Look to see if the rad needs flushed inside and/or out. A new rad cap, which changes the boiling point, not the actual temperature, is good that you have. Have you done any recent work to the car?
Old Sep 10, 2020 | 06:51 PM
Engine: LB9 305 TPI
It was running 180* up until recently. It's never ran this hot before. Before the thermostat replacement about 195.
Old Sep 10, 2020 | 06:55 PM
Engine: LB9 305 TPI
This has me really curious. A couple of months ago I had the flexplate replaced since it was making noise and it was warped. Could a new or not probably installed flex plate prevent the torque converter from locking up? What are some symptoms? I haven't noticed any slipping of the transmission.
Old Sep 10, 2020 | 06:56 PM
Engine: LB9 305 TPI
The coolant was flushed back in March. The radiator looks clean and it looked clean when it was empty back in March.
A few months ago the flexplate was replaced.
Old Sep 10, 2020 | 06:58 PM
:shrug:
And ... ??
You should know, I made a promise to myself NOT to answer "overheating" threads. But dumba$$ me, I made an exception on your behalf. They're mostly posted by ignorant people that hallucinate they have some sort of superior "knowledge" about temperature that's not available to people with backgrounds in things like physics and engineering, even though their backgrounds are often in nothing more scientific than ... I won't say. I thought you WEREN'T one of those. Sorry. I'll bow out now, and renew my vow.
I'm thinking the flex plate per se is not involved.
Old Sep 11, 2020 | 09:00 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Well if it ran cooler before the thermostat change, could it possibly be a bad thermostat?? I dont know exactly how they work but could it be possible that at sustained higher rpms that the extra coolant flow is pushing a "weak" thermostat partially closed?? Whenever I changed out thermostats I never put the stock style in, I always used the mr. gasket aftermarket ones and 180 degree, and mine never went over 200 degrees and usually ran 190-195 on the highway.
Old Sep 11, 2020 | 09:18 AM
ULTM8Z's Avatar
What prompted the thermostat change in the first place? If the operating temperature prior to the thermostat change was satisfactory to you, why not just put the old thermostat back in?
BTW, the flex plate has absolutely nothing to do with the converter lock up function.
Old Sep 11, 2020 | 01:55 PM
stron3's Avatar
Car: 87 Camaro Z28
It's not unheard of for new parts (including thermostats) to fail a short time later. Just sayin'.
Old Sep 12, 2020 | 08:40 PM
Engine: LB9 305 TPI
I put the Mr. Gasket 180 degree thermostat in the car. I was recommended it by a few people. It was running fine up until recently.
Old Sep 12, 2020 | 08:41 PM
Engine: LB9 305 TPI
I felt that running at 180* was a better temp compared to 195*. I tossed the old thermostat... I'll probably pull the current one to see if it failed. Throw it in boiling water.
If the heater works, doesn't that mean the thermostat works?
Old Sep 12, 2020 | 08:50 PM
ULTM8Z's Avatar
I don't believe so. The heater picks up water before the thermostat.
Old Sep 14, 2020 | 05:45 PM
Engine: LB9 305 TPI
Alright good news. I have a spare ACDelco 180* thermostat laying around. I remember I brought both at the same time. I was original going to just use the ACDelco but reading threads on this forum some people recommended the Mr. Gasket. I'll pop it in there tomorrow and full around the the Mr. Gasket thermo later.
I did notice that my airdam looks a little bent. It's very lose and has a lot of play. I'm also missing a few bolts. I think it might be time for a replacement.
Old Sep 14, 2020 | 05:49 PM
ULTM8Z's Avatar
Anything that needs high reliability i typically go with factory over aftermarket. Ignition components, alternators, water pump, etc...
Aftermarket and remans are often times $h!tty quality.
Old Sep 14, 2020 | 06:53 PM
Engine: LB9 305 TPI
Yeah. 99% of the parts on my car are ACDeclco. Hoses are Gates, exhaust is Hooker and all gaskets are Fel Pro. The alternator and fan motor are Bosch.
Old Sep 14, 2020 | 08:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
2 Hot, Know It Knot
"I don't think 200-220 is damage level"
Definately not.
I once drove home a work in progress at 260°, with no damage.
Of course you don't want to have it there on purpose due to the fact there is no margin of safety.
We're assuming you're running approx 65MPH.
Sustained triple digit speeds can cause 220° range temps.
We're assuming no leaves between rad and condensor.
Check the engine timing, make sure you're not running lean.
Coating from 'StopLeak' can hinder cooling.
An overheating trans can add too much heat to the rad.
Even tho 220° is normal, I, like many others like to see the temps far below that.
When your rad is 180° it's better for the trans.
I don't use a thermostat.
That's controversial, some might say 'coolant's moving too fast, no time for heat transfer'.
However I love seeing my temp gage to the left.
Another advantage of no stat is — when the engine is cold, and I lower the coolant a few inches, then start the engine, I can see the flow from the rad tubes to the rad tank, verifying excellent flow.
HappyRacing!
I Didn't Wreck, The Track Moved
Old Sep 14, 2020 | 10:00 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I heard a 170 Degrees thermostat was optimum for the 3rd gen TPI motors? Any thoughts? Mine was running hot, I had to burp the system and I replaced the temperature sensor in the front of the motor. Fans come on as they should and car runs very cool locally and on the highway.
Old Sep 14, 2020 | 11:06 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 2 Hot, Know It Knot
Definately not.
HappyRacing!
No, the coolant doesn't flow too fast to cool, it can flow so fast that cavitation and aeration can occur, which can cause overheating. If your car is running cool, I guess it's not an issue in your case. Obviously you don't drive it in the winter...
Old Sep 17, 2020 | 12:29 PM
Engine: LB9 305 TPI
Update. So the 180* thermostat ended up being wrong, it was a 187* meant for a late model Tahoe/Suburban. So I returned and they gave me another one, I looked at it before I left the autoparts store and it's another 187* meant for the late model tahoe/suburban. So he ordered me another one and again it's a 187* meant for a late model. For whatever reason all of the ACDELCO 12T1D's are another ACDELCO box with a 12T1D sticker stamped over it. How this happened 3 times, I don't know. I ended ordering an ACDelco from Rock Auto. I might also purchase a Gates 180* from the Autoparts store and use that for now.
This morning I did decide to do a flow test of my car. When I started the car, one thing I did notice was my AC Compressor was engaged even though the lever was off inside. It began to squeal. I killed the car, unplugged the compressor and let it idle for 20 minutes. Now I wonder if the AC Compressor was running the entire time and that's what some how shorted the fan controller and has been causing my car to run at 220 even at highway speeds. I'm assuming the AC Compressor always on with out a fan would cause things to get hot?
After about 20 minutes, the car was at 175* (measured by temp gun), there was coolant in the upper and lower radiator hoses. I'm assuming this is a good sign the thermostat is opening? I'll take it for a long drive later and see how she performs.
apie2546
May 30, 2016 12:09 PM
maroon88iroc
Sep 28, 2006 08:46 PM
IroczCamar0
Jul 18, 2003 02:31 AM
TexasLT1
Sep 4, 2002 03:58 PM
jcjohnston78
Aug 14, 2002 08:58 PM
