Hello everyone. I've noticed recently that my radiator cooling fan (single fan, originally LG4 car with A/C delete) hasn't been turning on even between 220 and 260 degrees. I've tested the fan itself by hooking it up to the battery and also tested the relay by grounding the fan switch wire. All good there. I've also replaced the fan switch itself and even the connector but to no avail. Is there anything I'm missing here? Thanks in advance.
1989karr
close
- Join DateFeb 2005
- LocationHawaii
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car89' Firebird / 87' Formula
- Engine3.4 / 5.0
- Transmission700-R4
- Axle/Gears3.42 / 3.42
- Liked:201 Times in 187 Posts
You replaced the switch on the passenger side head, right?
If so, did you lookk for frayed wires at the relay? I had soem ugly wires that were grounding so I put some elctric tape on them and all works like new!
Yes, on the passenger side. I have not seen any frayed wiring. I'll take a look.Originally Posted by 1989karr
You replaced the switch on the passenger side head, right?If so, did you lookk for frayed wires at the relay? I had soem ugly wires that were grounding so I put some elctric tape on them and all works like new!
This is what I'm looking for?
I replaced a fan switch lately with an AC Delco on e that didn't work when new. Got one from advance auto that works great now. Only other possibility I can think of is the switch not grounding due to too much teflon tape or sealant already on the switch. You can check for continuity between the switch body and ground to eliminate that as a problem
Quote:
Does the switch ground via the threads?Originally Posted by henryd3
I replaced a fan switch lately with an AC Delco on e that didn't work when new. Got one from advance auto that works great now. Only other possibility I can think of is the switch not grounding due to too much teflon tape or sealant already on the switch. You can check for continuity between the switch body and ground to eliminate that as a problem 1989karr
close
- Join DateFeb 2005
- LocationHawaii
- Engine3.4 / 5.0
Quote:
Originally Posted by MrCaswell
Does the switch ground via the threads? Yes, it grounds via the threads, so if you put too much teflon tape in it it can;t ground.
That connector looks ok... but isn;t the cooling fan relay up front by the radiator area?
mine is right by the air box. 87 TPi Formula
That one you got might be for the fuel pump?
it looks similar if I am not mistaken.
Looks like the right 5 wires. Different years different locations and forms?
1989karr
close
- Join DateFeb 2005
- LocationHawaii
- Engine3.4 / 5.0
Looks like the right 5 wires. Different years different locations and forms? could be!
My cooling fan relay is by the air box but I also have a relay there that looks the same as the OP in the same area though.... Might be fuel pump but i have no clue lol
