Rubber ring around thermostat
Old Aug 6, 2021 | 11:48 AM
BytePaul's Avatar
Transmission: ...was received.
I replaced my thermostat recently since I had the housing off. The old thermostat had what appeared to be a rubber ring around the edge of the unit. The new one does not have one. I did get the gasket that seals the housing. My question is does a rubber ring seal go around the actual thermostat?
Old Aug 6, 2021 | 12:04 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Rubber ring around thermostat
Depends on the outlet housing and intake if the O-ring is required or if it is just a gasket. You should see a recessed shelf in the intake if it uses an o ring, if it is more or less flat with just a slight shelf for the thermostat then use a gasket. From the factory yours should have been using the gasket with a flat water outlet.
Old Aug 6, 2021 | 03:23 PM
BytePaul's Avatar
Good to know. I'll check it later. Thank you!
Old Aug 6, 2021 | 04:58 PM
BytePaul's Avatar
Here's the picture. Based on your description, and my lack of knowledge, I don't know if I should or not use a rubber seal around the thermostat. There is a tiny bit of sideways movement when the thermostat is in. Seems all the ones I find for the car are ones that do not have the seal.
Old Aug 6, 2021 | 06:41 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
on a SBC? I've never seen a oring. The housing you have is probably flat, in which case, use a gasket
Old Aug 7, 2021 | 08:24 AM
BytePaul's Avatar
Yes, the housing is flat. I will just use the thermostat as is. The person who had it before me had a thermostat with the rubber ring in it so I wanted to be sure. Thanks you two!
jeremyb1988
Aug 1, 2017 06:54 PM
jimw67
Apr 8, 2016 04:33 PM
AF_Medic
Mar 16, 2010 05:25 AM
JeffC1500TBI
Jan 26, 2002 09:48 PM
