water pump
Old Apr 25, 2022 | 03:20 PM
Bavooz Flo's Avatar
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
water pump
Hello,
My water pump is tired .... I live in France and I want to pass an order at RA and I don't want to make mistake......on GM SPARE, it is for an 1987 firebird trans am GTA 1987, 5.7L TPI.
2 choices of water pump for standard users.:
Airtex AW1121 or Gates 43099
https://www.rockauto.com/fr/moreinfo...=2208&jsn=1827 => two gasket + the plug
https://www.rockauto.com/en/moreinfo...pt=2208&jsn=14
https://www.rockauto.com/en/moreinfo...08&jsn=8&jsn=8
I don't know if it is the good deal because there a lot of choice..... perhaps another better for not more expensive.
But Gates is the only one with the plug if mine is off and rusty ..it is better choice perhaps.
Old Apr 26, 2022 | 07:16 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: water pump
id personally go for a delco.
but out of the 3, id go with the gates
Old Apr 26, 2022 | 07:51 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: water pump
Gates will probably be fine. I'd use fel pro gaskets and hi temp thread sealant on the bolts.
Old Apr 27, 2022 | 11:05 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: water pump
Originally Posted by Bavooz Flo
Hello,
you can have yours rebuilt. will be back with link. http://www.water-pump-rebuilders.com/ See the europe link, I had mine rebuilt, wanted to keep factory pump. they did a great job.
Old Apr 27, 2022 | 12:41 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: water pump
Curious, what does this service cost?
Old Apr 28, 2022 | 09:46 AM
LiquidBlue's Avatar
Transmission: MD8
Re: water pump
I don't recall, but it wasn't outrageous
Old Apr 29, 2022 | 07:15 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: water pump
Gates makes a good product
Old May 1, 2022 | 01:48 PM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Re: water pump
thanks everebody, I have buyed one Gates
James-Ingram
Dec 31, 2011 06:11 PM
shadow315
Oct 28, 2010 11:28 PM
1tpi
Jan 7, 2007 09:20 PM
