AC high pressure switch for secondary fan.
Old Sep 4, 2022 | 12:08 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Is this
https://www.ebay.com/itm/26117483727...VozTEKHjQbfQto
Interchangeable with this?
https://www.rockauto.com/en/moreinfo...19465&jsn=1047
Quite a difference in price.
Old Sep 4, 2022 | 12:31 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: AC high pressure switch for secondary fan.
Good question. Bump.
Old Sep 4, 2022 | 12:35 PM
chazman's Avatar
Axle/Gears: BW 3.45
I'd automatically go with the AC Delco one, but that seems like a ripoff price.
Old Sep 4, 2022 | 12:50 PM
BizJetTech's Avatar
IMO, as long as the operating pressures, thread size and style and clocking for the plug are the same, they should be interchangeable. It appears that way to me looking at the pics but I cant say for certain.
But, how can you go wrong at only $22 ?? What car is it for? Your cars you better pay up and go AC Delco
Old Sep 4, 2022 | 01:16 PM
chazman's Avatar
Axle/Gears: BW 3.45
Adam, there's a shrader valve under there, right? No need to evacuate the R12?
Old Sep 4, 2022 | 01:25 PM
BizJetTech's Avatar
I cant remember, I'd need to pull out one of my GM shop manuals to refresh my BAD memory
Old Sep 4, 2022 | 02:43 PM
BizJetTech's Avatar
Old Sep 4, 2022 | 03:37 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks bud!
Old Sep 5, 2022 | 06:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I didn't spend an hour of researching/ checking/following part numbers to give you a wrong answer.....
Old Sep 5, 2022 | 08:28 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks! Already ordered.
Old Sep 6, 2022 | 09:37 AM
chazman's Avatar
Axle/Gears: BW 3.45
BTW, the switch is further forward, about equidistant from the accumulator and compressor.
Old Sep 6, 2022 | 09:51 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Maybe it is me but I do not see the results of your search and efforts. What part number(s) do you recommend to activate fans at a lower than OE temp? For my 89 IROC 305 LB9 AT car. Thanks.
Old Sep 6, 2022 | 09:52 AM
chazman's Avatar
Axle/Gears: BW 3.45
deadbird and I spoke via PM.
Old Sep 6, 2022 | 09:54 AM
BizJetTech's Avatar
Sorry, I thought you were looking for the A/C press cycle switch ??
Old Sep 6, 2022 | 10:31 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I would appreciate seeing the results of your efforts, regarding AC cycle switch and radiator fan switch's. I am not requesting additional work, just what you already found. PM if you wish. Thanks, again.
Old Sep 6, 2022 | 11:17 AM
chazman's Avatar
Axle/Gears: BW 3.45
My first post have the two options for an AC high pressure switch. Kev confirmed that in a PM. I will almost always go with an AC Delco part if available. Even if it costs more. Even if it costs double. But I'm not getting ripped off at 6 times the price, so I ordered the 4 Seasons one from Rock. This only to get the secondary cooling fan to operate normally. I confirmed the relays are fine. When I jumped the connector to the high pressure switch the secondary fan started with the AC on.
I'm assuming there is a schrader valve under there though. Otherwise we are going to have a big mess.
Old Sep 6, 2022 | 11:40 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Thank you. I prefer OE, but at that price difference, 4 Seasons has been around a long time and I would get that one, also. Yes, there was originally a Schrader valve under said switch. So unless some Buffoon removed it, which I have never seen happen, you will be OK!
Old Sep 6, 2022 | 12:11 PM
chazman's Avatar
Axle/Gears: BW 3.45
I am the original buffoon who's owned that car.
Old Sep 6, 2022 | 12:19 PM
BizJetTech's Avatar
Too funny Charlie
Old Sep 6, 2022 | 01:31 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Too funny Charlie
"say it ain't so, Chazman"! You didn't delete an AC Schrader valve!
Old Sep 6, 2022 | 01:36 PM
chazman's Avatar
Axle/Gears: BW 3.45
Nooooooooooo! I would never commit such hackery.
Old Sep 7, 2022 | 08:52 PM
deadbird's Avatar
Engine: TPI 305/ v6
Apologies to all... I was not meaning to be a d--k to chaz.
I would also like to clarify RA is wrong on this part year range
This a/c switch is for 88-92... not 85-92
85-87..this switch worked opposite (chassis ground) of what is available.
Old Sep 7, 2022 | 09:17 PM
chazman's Avatar
Axle/Gears: BW 3.45
No worries. Glad to have your input.
Old Sep 9, 2022 | 10:01 PM
chazman's Avatar
Axle/Gears: BW 3.45
So the 4 seasons one doesn’t fit. The notches don’t fit the connector.
Old Sep 9, 2022 | 10:06 PM
chazman's Avatar
Axle/Gears: BW 3.45
Factory
Old Sep 10, 2022 | 05:55 AM
BizJetTech's Avatar
Bummer, I was a little concerned the clocking would be off and that looks like the case here
Old Sep 10, 2022 | 09:11 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
That is too bad!
Old Sep 10, 2022 | 07:27 PM
deadbird's Avatar
Engine: TPI 305/ v6
Well not only does that suck.. research has failed me and you and now, I'll eat my shoe.
It does appear the locking clip tab is correct, the alignment tab is off.
Technically, you could shave the alignment tab off and plug itvin.
There is no polarity (I know the align tab keeps it from spinning to) so,, as long
as the function is correct ... open w/ac off, closed w/ac on, should work.
The switch simply closes to ground.
This lets ecm know to run the primary fan cause ac is (charged) working and grounds 2nd fan (like fan switch)
4Seasons has a matching plug though
https://www.rockauto.com/en/moreinfo...=17535&jsn=528
Sorry for giving you a s___ alternative part chaz
Old Sep 11, 2022 | 12:26 PM
chazman's Avatar
Axle/Gears: BW 3.45
Just ordered the OEM one on eBay. Ouch!!!
Old Sep 13, 2022 | 12:52 AM
chazman's Avatar
Axle/Gears: BW 3.45
Man, I just noticed the guy raised the price of that switch to $138!!! Add another $20 for shipping and tax.
Old Sep 14, 2022 | 11:19 PM
chazman's Avatar
Axle/Gears: BW 3.45
My $150 switch came in. I'll let you guys know how it works.
Old Sep 24, 2022 | 12:53 AM
chazman's Avatar
Axle/Gears: BW 3.45
I almost forgot to get back to you. Yes, the way over priced high pressure switch did the trick.
Old Oct 27, 2022 | 07:27 PM
chazman's Avatar
Axle/Gears: BW 3.45
coolcamaroZ28
Feb 9, 2020 07:32 PM
89fast5oh
Sep 5, 2013 02:15 AM
eddie jr
Sep 1, 2012 06:19 PM
WestOzGTA
May 21, 2007 11:12 PM
ZFORCE
Apr 21, 2003 01:25 PM
