Part number or name for this heater core like
Old Jun 18, 2023 | 09:00 PM
DGGM92Camaro's Avatar
Car: 1988 Camaro IROC-Z
Engine: 5.7 TPI
My 88 IROC with the 350 TPI has developed a pretty strong leak from the metal return line labeled as the leftmost (2) on the below diagram. Where can I source once to replace it with?
Old Jun 18, 2023 | 09:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Part number or name for this heater core like
You could check GM stock and see if they still have one or get one from a parts car.
Old Jun 18, 2023 | 11:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Delete it and put a standard 2 port valve. Use a piece of hose for the return. Really cleans up the coolant routing. If you are really stuck on keeping the coolant bypass function for some un-known reason, use a 4-port valve for a 97 Suburban/Express Van. That metal pipe is nearly made of unobtanium and often ends up leaking because it rusts through as most if not all are thin steel rather than aluminum.
Old Jun 19, 2023 | 06:22 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you have a part number:
https://www.rearcounter.com/
https://www.partsvoice.com/
Good luck
Old Jun 20, 2023 | 09:21 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Part number 14101549. Discontinued in 2010 and no stock on hand at any GM location. Parts car is the way to go.
Old Jun 20, 2023 | 02:32 PM
If you get one off a parts car it will be just as rusted inside as your failed one. A temporary solution ONLY at best.
Don't bother with another steel one. It's quite easy to make one out of copper tubing, which will probably outlast the engine castings.
Old Jun 20, 2023 | 05:26 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Roll some (hose) beads in the tube and you'll have a real trick replacement.
Rauch
Dec 24, 2010 08:59 PM
FoxRodder
Dec 19, 2005 06:08 PM
llvll4l2c91350
May 3, 2004 02:54 PM
Tyler-88
May 3, 2003 02:59 PM
MikeT 88IROC350
Jan 29, 2002 06:46 PM
