Looking for a reliable HO fan
Old Jul 23, 2023 | 08:29 AM
ponzia's Avatar
Car: 1986 Firebird Trans Am
Engine: 383 Stroker
Transmission: 1996 T56
Axle/Gears: Stock 3.26
Looking for a 12" high cfm fan for my 86 firebird? I have used a dual Derale #16925 but failed after about 1000 miles, seems like many people about failing. Looking for a reliable fan
Old Jul 23, 2023 | 09:03 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Looking for a reliable HO fan
Mechanical fan is as reliable as you can get. Next best is dual electric. Use the search function on this forum. Pretty sure one or two other people have asked the same question since 1986.
Old Jul 23, 2023 | 12:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Do you know what went wrong with the Derale fan? I had an aftermarket fan lock up on me once-magnet came loose,took the motor apart and epoxied the magnet back in place and it was fixed. Very easy to come up with a dead-reliable E-fan setup,or you could install belt drive fan that will have some advantages and disadvantages vs E-fan. Fans mounted close to the radiator without a shroud can work good even with less core coverage because the concentrated airflow helps strip away insulating boundry layer effects from tubes and fins of the radiator. or oil cooler for more effective heat transfer to the moving air
Old Jul 23, 2023 | 01:03 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Have you looked into Spal fans? I use a single 16in spal and it moves a lot of air. Actually needed a 70 amp relay for it. They have all different options to choose from.
84TA_Guy
Jul 8, 2021 11:01 AM
Black Z28
Mar 23, 2010 02:23 PM
MY87LT
May 28, 2009 01:29 PM
MarkS
Sep 15, 2001 11:02 PM
