How to keep my cool??
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys I'd like to know how y'all are keeping your 3rd gens cool when it's 100-110 outside??
In my 91 I was driving on the highway doing about 70-80 mph and I was still seeing engine temps of about 210. I've got a 160* thermostat, Griffin 3" aluminum radiator with 2 Derale 12" pusher fans going at the same time too. The fans push a total of about 4000cfm. I figured that should've worked but hot damn it runs too hot for my taste
Any ideas to help a guy out would be appreciated. Thanks
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: How to keep my cool??
What car are you driving?
Is the air dam/deflector under the car?
Have you checked to make sure your heater core isn't restricted?
I have a 91 TA Vert. 305 TPI.. All stock fans and radiator. The P.O. installed a chip and a 160 thermostat from Harris performance tuning, and my car never sees more than about 185, even today in central Texas. Over 109 degrees with the AC on.
Air dam under the car is there
I've got no heat or AC
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Is your hot side coated or wrapped? Do you have a turbo blanket?
I have a turbo LQ4 similar to yours and I’m seeing 213 driving on the highway but I don’t have a hood on the car yet. I have turbo blanket, jet hot coated hot side, air dam, 2 row mishimoto radiator and 4,000 cfm derale dual puller fans.
LS engines run hotter than the small blocks that came in thirdgens. I’ve read that the fans in LS fbodies don’t even come on until over 220.
The car was at 210 but never went higher but never got cooler
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
86 z28 Camaro, 355 nitrous sbc, stock radiator, stock fans with a 185 degree fan switch and a 180 degree thermostat. Will run at 200-210 on a 100 degree day out on the street.
85 Iroc with a 305, mild cam and iron heads, stock fan and radiator. Same 185 degree fan switch and 180 degree thermostat, that engine will run about 190-200.
both engines have stock water pumps, no ac accessories or condenser, both also have cowl hoods with vents on the back, not sure if that would make any real difference tho. Both also have the connection points where the heater hoses would go plugged. And both also don’t have any heat risers in the manifold, again don’t know if that would make much difference in operating temps.
For the OPs car would it be possible that a pusher fan is spinning slower and letting less air through than the outside air would be able to naturally flow through the radiator at 70mph causing a restriction at highway speed? I hope that makes sense lol but that can apparently be a negative of a pusher fan vs a puller mounted behind the radiator which won’t block airflow at higher speeds.
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
I'd be interested to hear too. Twin gt35's on a 5.7 vortec. 195 thermostat, Griffin rad, two fourth gen fans and bigger air dam installed. Turbo blankets, wrapped downpipes, and vented hood where the IROC louvers were. It goes to 210 always on the hwy but never above and I cant seem to get it lower. At low speed, it'll drop 10 or 15 degrees. No space for a bigger rad either...
Engine: 5.0/5.7 LT1
My 4th Gen Trans Am LT1 Vert actually runs cooler with the A/C on because of the way the fan(s) are programmed/set to come on.
Car: 1983 G20 Chevy
Transmission: 4L60
https://youtube.com/shorts/xtH17jWIbHI?feature=share
Just move north.... In NY I don't even bother to charge my AC...
... And I just run 160 all day long ...
These cars just didn't seem to be designed for big time cooling... I wonder if they saw these challenges when designing these cars.
I think we need more radiators... Like a Veyron...
... And I just run 160 all day long ...These cars just didn't seem to be designed for big time cooling... I wonder if they saw these challenges when designing these cars.
Got it all sorted out, I changed the coolant temp sensor to a Rife liquid sensor a little while ago and must not have got all the air out of the system. I popped the cap off and let it run until it got up to temp and sure enough after about 10 minutes there was a big burp and coolant level dropped enough to get about 3/4 bottle back in.
Thanks guys for the input. Have fun!
