Biggest Radiator That will clear V-belt?
Old Aug 30, 2023 | 01:33 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
I have a 1986 Firebird and while it stays cool under normal driving, when I need to climb a long hill or put some load on it for an extended period of time, the temperature spikes and I haven't found a point where it will stop getting hotter without lifting (And I don't plan to). Does anyone have any affordable recommendations for radiators with heat capacity for 400+hp so I have some breathing room? It MUST be an easy install because the car is my daily driver as of right now. (Obv it's a V belt car because 1986)
For reference:
I am using 4th gen LS car dual fans with shroud on the stock radiator that was pressure tested and cleaned about a year ago when I put a new motor in the car, and I have a transmission cooler stacked on top of it along with functional Air Conditioning. My air dam is in place and functional.
jamon8
Aug 21, 2009 05:27 PM
xxx3man`
May 27, 2009 06:33 PM
crewguy
Jun 21, 2006 12:22 PM
FirebirdRacer89
Aug 26, 2005 06:01 PM
Dustin Mustangs
Apr 4, 2002 11:54 PM
