Thermostat housing & hose
Old Nov 14, 2023 | 02:53 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Those that have put on an Edelbrock type intake what thermostat housing & upper rad. hose did you use? I'm having trouble coming up with a match.
Old Nov 16, 2023 | 10:13 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Thermostat housing & hose
Factory hose and a generic housing
Old Nov 16, 2023 | 12:37 PM
BBCSwap's Avatar
Factory hose is too short and it takes a 1 5/16 connection. Thanks.
Old Nov 16, 2023 | 12:50 PM
midias's Avatar
I am running this housing and hose no issues
Amazon Amazon
Gates 21204 hose
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So you are saying the Eddy intake have the t-stat housing in a different location, making a factory hose too short?
Old Nov 16, 2023 | 03:39 PM
BBCSwap's Avatar
Correct. The TPI manifold has the thermo housing to the left of center, it is longer, it sticks out in front of the block just over 3" and is 1 5/16 dia.
I have a Mr. Cool radiator that came with the car. It has a 1 3/8 dia. water neck. I don't know if the is stock size or not. I don't know if I have a stock upper rad. hose. But it fits the TPI perfect.
The pic of the sbc 400 I have the rad. hose pulled as far as it will go. I have a swivel thermo. housing coming & a 1 1/4 to 1 1 1/2 reducer coming. My hose will tighten up on the 1 1/4 end. The swivel will help so it's not pointing to the air intake creating interference. Any thermo. housing I find for a sbc has a 1 1/2" neck.
Old Nov 17, 2023 | 07:47 AM
BBCSwap's Avatar
Gates 21204 hose
That hose shows 1 1/4 on one end and 1 1/2 on the other. I don't think I will be able to get the 1 1/4 end on my 1 3/8 rad neck. What is your rad neck diameter?
Old Nov 17, 2023 | 10:41 AM
midias's Avatar
Have you tried the gates tpi hose?
https://www.rockauto.com/en/moreinfo...35830&pt=10068
Old Nov 17, 2023 | 03:51 PM
BBCSwap's Avatar
My parts will be here tomorrow....so the tracking says. And then I can start it for the first time. Yee Haa. I did put that hose in my notes. I don't know why that TPI hose is different than mine? Thank you very much.
randyhummel
Canadian Region
Jun 15, 2020 09:59 AM
al1989
May 26, 2012 06:52 PM
lon1986TA
Apr 9, 2006 12:24 PM
SLAYER6669
Jul 22, 2002 02:03 PM
