Replacement Air Dam
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Replacement Air Dam
Just like the title says, where does a guy get another one in decent shape?? I was backing out of a buddy's place and mine ripped right off but the bolts stayed in place. I've spotted a few used ones on ebay but even they look questionable. Are new ones still out there decently priced?? Also how big are these things supposed to be? Mine has a really mean curve to it and there's maybe 2 inches left of it so I'm assuming it's time to replace it anyway and it's about as thin as a piece of paper.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Replacement Air Dam
I got a brand new unit off of flea bay
1985-1990 Pontiac Firebird Formula Trans Am Front Lower Air Dam New Reproduction | eBay
Engine: 3.4 / 5.0
I literally just typed in "Trans Am Air dam" but sometimes in the app you need to scroll la bit to find things
Eeeeeeezzzzzzzyy to make one out of 18-wheeler mud flap material. Not only is it cheeeeeep, butt also, it bends out of the way in situations like yours.
Make it so that it goes to about 1½ - 2" off the ground. The tradeoffs that come with height variation should be obvious enough.
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you didn't rip through the bolt holes you can just use a larger washer and bolt it back in.
Engine: 4++,350 & 305 CIs
GM parts book calls them "deflector" so try air deflector in searches as well.
Thanks guys for the suggestions. I managed to get one from a GM parts Depot on sale. $100 CAD shipped
I would think, the closer to the ground it is, the better it would work. You'd probably want it as low as you could stand it without it getting torn off which would obviously reduce its value significantly. Hard to say how much difference there'd be between say 2" and 1" in just pure effectiveness. It creates both high pressure in front of it and low pressure behind it, so it drives airflow through the rad from both sides.
Car: 1986 TRANS AM
Engine: LB9
I had this on my TA 1985 back in 1989. Deep curves scratch..... Inclines sometime scratch. So what its durable somewhat flexible will take the abuse it. It was worth its weight in Gold in keeping the engine cooler engine Temp.
