cooling fan not coming on
Old Feb 27, 2025 | 03:48 PM
Firebirds's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Transmission: World Class T-5
the cooling fan does not come on unless ac is turned on. temps can and have gotten over 250 degrees consistently in ten minute drives of slow driving. Here is a photo of a sensor i found on the passenger and engine side of the radiator. It doesn't have a corresponding female plug. could someone follow theirs from the radiator and share some photos so I can see where the plug should be incase I need to fully rewire it?
Old Feb 27, 2025 | 05:02 PM
Re: cooling fan not coming on
That's a coolant level sensor. It being there allows the same radiator to be used in many other car models. That's not the original radiator that came in the car, it's a replacement.
Not related to the fan in any manner way shape form or fashion. Ignore it.
The fan's temp switch is in the pass side head, between the #6 & #8 spark plugs. The same hole that the gauge sending unit is in on the driver's side. Depending on what car and engine you have, the ECM may also be involved.
jpontiac
Feb 12, 2021 08:45 AM
miche25
Mar 10, 2019 11:13 PM
nateg
Aug 17, 2010 01:31 PM
billybob6110
Feb 12, 2009 06:30 PM
RODS92Z
May 31, 2002 07:25 PM
