Primary cooling fan runs all the time
Old Jun 24, 2025 | 12:51 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
Transmission: TH700-R4
Hi!
I have a small issue with my primary cooling fan.
The car is a Camaro 1988 with 305 TPI and TH700
My fan primary fan starts to run when I start my engine.
I have changed the fan relay, temprature sender ( the one in the fron of the manifold) but it still runs.
The green wire from the relay that goes to the ECU is fine and not damaged, and I cant see that anyone have done a mod or so to the fan wiring.
The ECU is set to 86 degree celcius as start value.
Have anyone some ideas where to look next.
Old Jun 24, 2025 | 01:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Primary cooling fan runs all the time
Is the fan switch for a/c set correct?
Old Jun 24, 2025 | 01:13 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
The primary fan is only triggered by the ECU.
The secondary fan have the high preassure sensor hocked up to the ac system, but the system is low on R134.
The temp switch for the secondary fan is broken and hooked up to a manual switch. It I jump the ac high preassure switch the secondary fan starts.
I dont think the primary fan will start with ac senders
Old Jun 24, 2025 | 01:24 PM
Engine: Lb9
Transmission: M20
So if c1 of the ecm is grounding the relay the ecm is faulty since it’s not commanded.
Old Jun 24, 2025 | 01:32 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
Okay. So you think it is time to change the ECU itself.
is it a common problem?
Old Jun 24, 2025 | 01:40 PM
Engine: Lb9
Transmission: M20
I’m pretty sure the fan switch in the tune would command the primary. But if all that’s fine and the ecm is grounded the relay not commanded then the ecm is bad. Or it has a cold solder joint.i had a customer recently firmly press down on the memcal flexing the pcb it stopped the fan request. He reflowed the ecm joints but no success.
Old Jun 24, 2025 | 01:42 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
Okay. Thanks.
I’ll better look for a replacement ECU then.
I guess there are all the same 1988 tpi models, so I just move over the memcal
Old Jun 24, 2025 | 01:44 PM
Engine: Lb9
Transmission: M20
1227165 or superseded number, yes just swap the memcal
Old Jun 24, 2025 | 02:43 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
Thanks for the ECU number.
I have a local dealer in sweden that might have a ecu on stock, I will try that out as a next step.
cheers
Old Jun 24, 2025 | 03:02 PM
Engine: Lb9
Transmission: M20
Could ask this Facebook group the 165 was used 86-89 tpi
Old Jun 24, 2025 | 03:13 PM
FredrikM's Avatar
Car: Camaro Iroc-Z
thanks.
Cool that you found my post on that side
Old Jun 25, 2025 | 07:34 AM
Does the fan continue to run if you disconnect the AC high pressure switch? If you remove the relay?
Old Jun 25, 2025 | 08:39 AM
FredrikM's Avatar
Car: Camaro Iroc-Z
The fan runs when i remove the highpreassure switch from the ac line.
When i remove the relay, the fan stops.
Old Jun 25, 2025 | 08:50 AM
FredrikM's Avatar
Car: Camaro Iroc-Z
And also, the green/white cable at the relay socket that goes to the ecu are only grounded when the car runs. When stoped it is not grounded, so maby the ecu works
Old Jun 25, 2025 | 08:41 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Have you swapped the relay for a known good one? I've had them stick closed
Old Jun 25, 2025 | 09:25 PM
Engine: Lb9
Transmission: M20
iirc it’s the same as the fp relay or blower relay.
Old Jun 26, 2025 | 03:03 AM
FredrikM's Avatar
Car: Camaro Iroc-Z
yes, i have swaped them and it is still the same.
Old Jun 26, 2025 | 08:17 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Did you check the wires going to the cooling fan relay connector? Mine were all deteriorated. I added some electrical tape and found that the fan then worked properly as the wire insulation had decayed and was grounding out the wires
Old Jun 29, 2025 | 08:57 AM
FredrikM's Avatar
Car: Camaro Iroc-Z
I bought a hose adapter with a 95 degree switch and connected it to the fan relay. All good and works fine. I will see if I can find a new ecu in the future
stielow775
Aug 10, 2023 08:10 PM
MysteryMachine
Feb 28, 2013 08:12 AM
b_jeezy
Feb 15, 2008 08:38 PM
ReverendZ28
Jun 27, 2007 03:33 PM
restoIROC
Dec 30, 2002 03:07 AM
