1986 Camaro cooling fan
Old Nov 8, 2025 | 03:03 PM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
Hi Guy’s, I’m working on this 1986 Camaro fan which might be different than the later 2 fan setup. If I connect it directly to the battery it cycles every 40 seconds or so . Is this how they are supposed to work? There must be a heat sensor somewhere that allows the fan to run constantly. I was thinking to hot wire it but it just cycles. Anyone know how it works?
Old Nov 8, 2025 | 05:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1986 Camaro cooling fan
Certain GM fan motors have an auto-reset circuit breaker built in to protect the motor from snow jams-that circuit breaker is bad or motor is bad.New fan motor is the fix. Better if the fan is properly thermostat controlled as original .
xXasylumXx
Jun 28, 2020 12:02 PM
camaroinmotion
Dec 27, 2015 07:09 PM
tarheel
Sep 9, 2009 01:05 PM
gogo90camaro
Sep 15, 2004 06:12 AM
blue91rs
May 19, 2001 12:59 PM
