Electric water pump suggestions
I have a '84 sport coupe swapped with a 350 sbc. Its running electric fans and a cheaper 35gpm electric water pump and water temp runs up to 215. I want to keep it below 200. Mind you this is arizona weather with temps over 100 in the summer. Any water pump or cooling system suggestions?
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Electric water pump suggestions
well, living in pheonix, i would never run an electric water pump on anything other than a 1/4 mile only drag type of car.
your car worked just fine stock, try putting some stock stuff back onto it
what type of radiator and fans are you using?
pics help also so we can see what you see
where in az are you?
Car: 1991 Z28 Convertible
Transmission: "World Class" T5
Axle/Gears: 3.08
What was the original motor? How old is the radiator? If you jumped up from an iron duke or v6 to the 350 without a rad swap that could be part of the issue too. When my Lemons team did a swap on a 98 f body we found the v6 radiator wasn’t as thick as the v8 unit and the used one we got was full of crap. A quick check on rock auto shows a 20” core for the ol duke while the 305 has 26” cores listed. Just some more food for thought.
