ECM definition change, questions
Old May 18, 2002 | 04:51 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
I have a 1227165 on my 86 IROC, what do I have to do, to convert it from a $32 def setup to a $6E definition?
I know there are advantages, that sound like they will work for me, since I have a Mini-ram and have the lean out condition w/ backfire, and tip-in and I have the need to eliminate the cold start injector.
Is this easy, should I do this?
Tony
Old May 20, 2002 | 01:06 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: ECM definition change, questions
Tony
Disable or remove the cold start injector. It's as easy as removing the 3-amp Crank fuse, or as difficult as buying and installing a plug kit for the cold start injector and its little fuel line.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
