165 ecm
Old May 18, 2002 | 06:23 PM
91 RS's Avatar
165 ecm
i just purchaced a 1227165 ecm from a junk yard for my engine swap. I was wondering if it would work in an 89 tpi engine if i changed out the memcal and prom. the following numbers were on the ecm
SERV. NO. 1227165 ABWN
868161 M720031940
16068161 ABWN
(BAR CODE)
Old May 20, 2002 | 01:20 AM
Toms88am's Avatar
info you need:
www.chevythunder.com
Old May 20, 2002 | 01:03 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: 165 ecm
868161 M720031940
16068161 ABWN
(BAR CODE)
Yes, it'll work with the correct memcal (the prom is part of the memcal). BTW, the ABWN memcal is for an '87 Camaro with a 350 TPI engine, A4 tranny, 3.27 rear, and Federal emissions. You could easily use this to solder a ZIF socket to and burn your own proms.
Old May 20, 2002 | 09:01 PM
91 RS's Avatar
Thanks for your help guys unfortunately the chip was gone so I had to order a new mem cal and prom from gm
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
