how dose the air work
Old May 21, 2002 | 07:12 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok how dose the air work that gets injected into the exhaust. wouldn’t it make the o2 read lean all the time. can it be turned off and if i turn it off will it make the motor run any better. on top of this what will happen if i shut of the egr.
Old May 21, 2002 | 07:40 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: how dose the air work
It is only injected into the exhaust manifolds during open loop and (I think) power enrichment (aka: WOT). All other times (primarily when in closed loop), the air is diverted into the catalytic converter. You can disconnect the wiring harness, remove the air pump, plug up the holes in the manifold and cat, any of the above, and the computer won't care.
If you shut off the EGR (I assume you mean physically disable it), you'll probably set an SES code and might run into detonation problems when driving. The best way is to shut it off in the computer itself (burn your own chip).
Old May 21, 2002 | 08:18 AM
c4boom's Avatar
Engine: l98 and lo5
i was talking about shuting it of in the chip and i only have two lins coming of my air pump one to each manifold
Old May 21, 2002 | 09:10 AM
Engine: 385 HSR
If that's the case, then it shuts off once the computer is in closed loop. I'm not sure how to disable it in the chip itself, but I'm sure it can be done.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
