Which ECM could I use?
Old Jun 4, 2002 | 07:56 AM
felo72's Avatar
I have an 86 Camaro with a 350 TPI, the ECM is from a 305, could I use a 350 TPI ECM out of an 87 and up or are the connectors different for the ECM? If I can't change the ECM, could I atleast change the chip? Thanks for the help ahead of time...
I feel like this guy, running around in circles with this car:lala:
Old Jun 4, 2002 | 09:00 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: Which ECM could I use?
If you have an '86 Camaro, then your engine is a 305TPI unless you or a previous owner swapped it out for a 350. The 305 and 350 TPI ECM's are the same from '86-89, so they're interchangable. You can also change the chip, or start burning your own (see the DIY_PROM board) and upgrade to the '89 $6E code.
Old Jun 4, 2002 | 09:15 AM
felo72's Avatar
Thanks for the info, I would rather go with the stock computer from an 87 350 TPI Camaro rather than burn a chip for it. Only because I didn't put the 350 in it and I don't know what the compression is or the cam specs. Any ideas about how much an ECM would cost?
Old Jun 4, 2002 | 12:01 PM
Engine: 385 HSR
If your '86 computer is for a 305TPI and the part number for it ends in 165, then you can use that computer. All you'll need is the memcal (chip) for an '87 350 (broadcast code ABWN is for an '87 350 with Federal emissions and a 3.27 rear). I think you can get the memcal for about $40 from any Chevy dealer.
Old Jun 4, 2002 | 02:04 PM
felo72's Avatar
Thank you for the info.
:hail:
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
