Ecm Interchangeable
Old Jul 17, 2002 | 11:18 PM
Duke901's Avatar
Car: 89 Formula
Ecm Interchangeable
I have been looking at buying a 1987 formula with a tpi 305 and a 5 speed, but the biggest problem is that the computer is dead, so what i was wondering is that can i get a ECM from any year camaro or firebird and put it in. And does it matter if you put a ECM in from a automatic even though the car is a stick.
THANK YOU
MIKE
Old Jul 18, 2002 | 12:12 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
yes it does matter. you will have to find a car of the same year model an it has to be a stick. you whould be better off to go to the parts store and buy one. they are about 100.00 and 150.00 trying to find one will be two much of a hassle
Old Jul 18, 2002 | 12:32 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Your 1987 TPI uses a the same computer (1227165) as ALL TPI Corvettes, Camaros and Firebirds from 1986 to 1989. Also, 1987-1991 trucks with the 2.5 4 cylinder TBIs used the 1227165.
So yes, there are a number of other vehicles that did use the 1227165, but they are getting harder and harder to find. I can find 1227730 far easier because they were used in so many more vehicles.
You could always convert to SD. It's not that hard. I know a few guys that have converted to SD because it was cheaper than buying a new MAF.
Old Jul 18, 2002 | 11:40 AM
Duke901's Avatar
Car: 89 Formula
OK, what about putting a carb on it. What would be needed to do it. And would i be able to use a mechanical fuel pump or would i need to use a electric one. And would i lose any power by switching from tpi to carb. Or do you think it would be easier to stay with tpi and buy a new ECM.
THANK YOU VERY MUCH
MIKE
Old Jul 18, 2002 | 10:10 PM
Car: Death Mobile
Engine: 666 c.i.
THANK YOU VERY MUCH
MIKE
Scour wrecking yards and find a used 1227165 ECM. Should be able to pick one up for under $100, probably $50. But you may have to "search a little".
Also, don't ask for a "Corvette/F-body" ECM, it's amazing how those two words adds to the price. Say it's for a 1990 S-10 Pickup with a 2.5 Cylinder TBI. It's the same ECM. Just read the "sticker" on the ECM to make sure it has "1227165" on it.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
