Question about 90 ALDL
Old Aug 24, 2002 | 06:11 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
Is it different on the older models. A friends 89 works fine with the aldl cable he made but will not work with mine. It is getting no link or nothing at all. Or is the program ECM not made to work with SD.
Thanks, Gary
Old Aug 24, 2002 | 06:41 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
What scanner are you using? WinALDL doesn't support SD cars. Moates software supports both SD and MAF. Some of the older cars had the data line on the "E" pin of the ALDL connector and needed to have a 10K ohm resistor placed across "A" and "B" of the ALDL to spit out the 8192 baud rate as opposed to the 160 baud. The SD ecm doesn't need a resistor placed across A and B, but the data line is at "M" at the ALDL.
Old Aug 24, 2002 | 06:52 PM
Engine: L98 350
He was using Moates but i think it was a old version. This is what mine has
FEDCBA A,B,C and F have wires
GHIJKL bottom J and L Which wire is the data stream.
Thanks, Gary
Old Aug 24, 2002 | 07:06 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
You're missing M as there is no I. The data is at M which you think is L, it's an orange wire.
Old Aug 24, 2002 | 10:38 PM
Engine: L98 350
Thanks I didnt know what they were so i just called them any letter but that is exactly what i needed to know.
chazman
Aug 28, 2018 03:25 PM
masonta
Sep 1, 2015 06:40 PM
mike_c
Aug 27, 2015 04:32 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
