Where is my ECM??? t/a 87
Old Sep 7, 2002 | 03:44 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
Can anyone help me, Mitchell on demand say it's on right side of dash board, can't find it! If you had any picture that could help, i mean there must be alots of wires going to it!!!
Like the signature say, it's 1987 4bbl LG4.
My problem is the check engine , choke & shiftup light dont work,
when key to on, there shut.
I have then try a Snap-on scanner on the connector and i get no communication with the ECM!!
Also where is the Driver Light thing linked to the ecm in my wireing diagrams...
In mitchell procedure i need to disconnect the computer :}
Old Sep 7, 2002 | 06:14 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Its either behind what would be the glovebox or behind the right kick-panel. Its an aluminum box, unless its been changed to an aftermarket ecm.
Old Sep 7, 2002 | 11:42 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Would that position be also the same for an 87 GTA TA?
Old Sep 8, 2002 | 10:24 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Should be. Remove the kick panel on the passenger side and look up. If you see a square aluminum box mounted where the glove box would be...that's it.
Old Sep 8, 2002 | 02:31 PM
GTATransAM's Avatar
Ok thanks, i just recently looked inside there to disable the motor to my antenna, since it messed, but didnt pay attention for an aluminum box. If its there, great, its a good and accessible position.
Thanks.
Old Sep 8, 2002 | 04:31 PM
yanfoo's Avatar
i have look in the kick panel it's not there, i'll go take picture with a digital cam, brb i'll check if i can put it on a web page like an album, else i'll post only the pic in here.
Old Sep 8, 2002 | 04:43 PM
yanfoo's Avatar
PICS!!!
http://pages.infinit.net/airpy/yanfoo/
you can see the pics i have taken there...
I hope it's the small silver box... but it only have 1 connector
Thanks for your help!
Old Sep 8, 2002 | 06:06 PM
yanfoo's Avatar
ok i think the aqua little box is the light driver module
i can open the back of it and it's empty inside, if anyone know if it is realy the Light driver module and if it is suppose to be empty, the shape of it look like you can connect something into it, like a "module" !! anyway if i get no response before tomorrow i'll check it out in a 86 firebird that we have at school...
Old Sep 9, 2002 | 01:44 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Re: Where is my ECM??? t/a 87
Did you check to see if the bulbs are just burned out? Had a problem in my old '87 IROC (RIP), and after hours of messing around with the ECM and scanners and finding nothing wrong, it was just a bruned out bulb
Old Sep 9, 2002 | 01:52 PM
yanfoo's Avatar
I found out that i have a non-CC Qjet!!! wow
i stopped looking for the ecm when one of the teachers at my mechanic school told me too look if i had a tps on my carb, no i dont... so now i'll just look into how to tune the thing so i dont get that rich... i get a smoke cloud when i start it (yes and my valve seal make me burn oil, but it smell gas).
Old Sep 10, 2002 | 04:11 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
The first thing I would check is the choke operation. If it is hanging shut even a little you will be rich to the point of black smoke. Your valve stem seals should make a blueish smoke and should show up on your plugs as oily. Rich mixture should show up as a wet look that smells gasy.
Bob
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
Jlanz55
Sep 29, 2015 08:55 AM
