Do i need a new ECM?
Old Sep 30, 2002 | 07:57 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
After i did my 305 to 350 TPI swap and replaced the exhaust system with a hight flo cat and a magnaflow muffler someone said that i need to change the ECM when doing that? He said if i dont replace it i will have to go through another catylytic converter.
Old Sep 30, 2002 | 09:35 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
MAF car? You'll be OK. SD car, you should get a factory 350 chip.
Old Sep 30, 2002 | 11:21 PM
What is MAF/SD? How do i know which one i have?
Old Oct 1, 2002 | 06:56 AM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Does the mar have a mass air flow sensor (MAF)? If so, you're good to go. SD is speed density and uses a manifold absolute pressure (MAP) sensor to determine how much fuel to add but it needs to know cylinder size. That's why a chip change would be in order. If your car is an 86, it's MAF, unless someone went and changed it.
Old Oct 1, 2002 | 04:26 PM
Ya i looked checked and it is an MAF car. so i dont need to change anything?
Old Oct 3, 2002 | 09:59 PM
I called around and was told that i need a custom chip burned because of the 305 chip is still in but i have the 350 engine. It is still TPI. Does this sound right?
Old Oct 4, 2002 | 06:16 AM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
A MAF ecm doesn't need to know the engine size. If it were SD, it needs to know the engine size and would require a chip change. You have MAF, it needs nothing but if you would like to change to the appropriate 350 factory chip for you year car, go ahead.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
