chip ?
Old Oct 12, 2002 | 12:25 AM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
chip ?
I bought a stage 2 chip from jet and when i installed it the care ran terrible. I had to take the hole computer box apart besides it was a real pain.so i called them and asked why it wasnt running right and they said it was because their was a upgrade from gm on that chip and they would need to reprogram it. gm told me their was no upgrade for my 350tpi in 1989.also ever since i bought the car the lockup doesnt work so he said i should get that fixed first.bottom line i sent it back its junk anyway.my ? is this why didnt the chip work? whare can i get one that will? do i need to fix the lockup? do you think their is something else causing the problem?will i have the same problem with evry chip?
any help would be appreciated thanks.
Old Oct 12, 2002 | 04:50 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
First things first, fix the tranny (I assume you're refering to the lock-up converter and or lock-up switch). Then go to www.fastchip.com and order a chip. If you dont have anything major done to your car that would need a custom chip, just order their performance chip for an 89 IROC with a 350, it's like $159 or something. If you need an completely custom chip, they can do that as well for around $350, just give them a call.
Mike (1bad91Z)
Old Oct 12, 2002 | 09:30 AM
1987gt's Avatar
Car: 1989 GTA
I probably need the custon chip i have alot of bolt on mods thanks for the info.
Old Oct 14, 2002 | 08:33 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Learn to burn... your own that is.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
