engine rev limiter?
Old Oct 13, 2002 | 10:27 AM
dale davidson's Avatar
engine rev limiter?
ok, when i first got the '86, it would not rev past 4.7k, i took out the factory airbox, replaced with home depot racing spec drying machine ducting(aluminum stuff),home made airfoil and dropped a k&n, removed the top of the air filter box and sealed the filter with duct tape(messy but effective). added to that was a crack in the y pipe from trying to run from the cops (during my first and last street race in NYC) and following every one on to a dert road (that was the place to see body kits get wrecked).
any ways, the engine will now actually pull to the red line and bounce at 5000rpm, if this is the rev limiter, in theory, how would i make power to 5500 (after tpi porting) if the engine has a rev limiter?
Old Oct 13, 2002 | 10:48 AM
funstick's Avatar
i have yet to see a TPI ecm a 1227165 with a rev limit of 5000rpm. sounds like an ignition problem.
Old Oct 20, 2002 | 10:56 AM
so, in thery, if its the ignition, there is hope for higher rpm power, thanks for the bitter sweet nwes.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
