*newb* Will i need a new chip??
Old Dec 11, 2002 | 07:15 PM
mhaskell's Avatar
Pretty much stock car, 1992 SD 350 TPI auto currently:no cats flowmaster exhaust, but with manifolds. I am swapping to a t-5 and 1.6 RR. I assume that I'm fine with the stock chip? But can i swap in a zz4 cam if i got back to the 1.5 rockers and still use the stock chip? Exactly how far can i get and still retain drivablility/ mpg? Vortech heads? I am pretty good with computers (have built 3 watercooled systems) so hardware is not a problem if it comes to tuning via/laptop. Would it be a good idea to start off with simple data logging to get used to the TPI system? Something like this auction http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873912597 ? Anybody in the Boston/Providence area want to enlighten a guy like me? Thanks guys. -Mike
Old Dec 15, 2002 | 11:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
With a transmission swap you'll want to use a stock 5-speed bin such as AXXD. I used a ZZ4 cam with the stock 305 5-speed chip in my car and had no problems.
Old Dec 16, 2002 | 01:34 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I know absolutely nothing about burning chips yet, but I did purchased the data cable from the same ebay auction. It took about 10 days to get here, but it's a really nice quality cable and has a color print out of how the cable connects to the interface on the car. It took me about 10 minutes to get the moates software up and running with this cable. And most of that time was from me making mistakes setting up the software to talk to the car.
I've seen this cable go for up to $55 on his auctions. I waited and watched his auctions and got my cable for the starting bid plus shipping.
Old Dec 18, 2002 | 01:08 AM
Chevero's Avatar
The diffrence btween Auto and Stick ECM chips is great, but not easilly defined. The stock auto chip will get you okay performance (with the ZZ4 cam), but the stick chip (when a stick trans is used) will have better driveabllity, and through chip burning, you can get more performance. The Vortech heads will stretch the ability for the stock stick chip to perform, but should still be okay with manifolds. For optium extraction of performance though, chip burning is where you should be headed.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
