ECM..what it controls
Old Jan 23, 2003 | 08:11 PM
Kiwi-85IROC's Avatar
Is this true for an 85 TPI?
The ECM controls fuel delivery and ignition timing base on the OXY sensor & MAF sensor. Anything else?
Also what else does it control, fuel pump etc?
Old Jan 23, 2003 | 10:24 PM
llvll4l2c91350's Avatar
Some input devices used by the ECM would be O2, MAF, MAT, MAP (on 90-92 models), TPS, CTS, Battery voltage, crank signal from ignition module, A/C on switch, P/N switch, knock sensor, Vehicle speed sensor.
Some output devices would be IAC, ignition advance or retard, Fuel injector pulse width, fuel pump, Coolant fan control, TCC lockup, AIR operation, EGR, Canister purge, SES light.
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
