Diacom software- were to get specs?
Old Jan 30, 2003 | 10:39 PM
Tmony69's Avatar
Car: 89 IROC x2
I recently purchased Diacom's GM Plus and I'm trying to figure out how to find what the base line sensor outputs should be in the realm of normal operation. In situations where something may not be up to par, but not enough to set a trouble code, I want something to compare it to. For instance, I can see what my cars O2 is doing, but what would a normal O2 output be. Does this make sense?
Old Feb 3, 2003 | 08:06 AM
JPrevost's Avatar
Car: 91 Red Sled
There are explinations all over this site, just do a search. Also Diacom has it's own built in explinations. They're helpful, hope you find em.
Old Feb 3, 2003 | 09:23 AM
Tmony69's Avatar
Car: 89 IROC x2
Thank you very much. Have you had a chance to use Diacom? If so what do you think?
Old Feb 3, 2003 | 10:43 AM
JPrevost's Avatar
Car: 91 Red Sled
I have it. It's old but nothing is as flexible. You need to know very little information about the vehicle (enter vin) and select the engine. It supports OBD1 vehicles up until 95, not sure about Lt1's but I know it works on 95 TBI trucks. It's just SO old that I avoid using it when other options are avail. I prefer winaldl with the 160 baud ecm's but for the faster stuff, diacom rocks. Craig's software is also great especially since it's free.
Since the software is old it can be used on a 386 laptop run off the floppy. The other thing I don't like is the price. It's expensive so avoid it if you can.
Old Feb 4, 2003 | 12:09 PM
Miami's Avatar
Where can I get Diacom Software or Something that will work with
an after market Chip?
Old Feb 4, 2003 | 01:14 PM
JPrevost's Avatar
Car: 91 Red Sled
The aftermarket chips don't have anything to do with the ecm's aldl data stream. If they did change the code to prevent accurate data through the aldl then they're idiots. So Craig's software or winaldl will work with your car and it's free, Diacom costs over 500 bones.
Old Feb 7, 2003 | 09:58 PM
Miami's Avatar
Hey Thanks! But can you give me the URL to Craig's software and winaldl?
Old Feb 8, 2003 | 02:01 AM
JPrevost's Avatar
Car: 91 Red Sled
http://www.winaldl.webhop.net/
http://moates.net/gmecm/software.html
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
