VAT with Accel Gen VII
Old Apr 21, 2003 | 09:03 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello all,
I have a '89 Firebird 305, TBI, with ATI Procharger. I am converting it to a accel superram and Gen VII DFI. The garage that is doing this told me that they had to program the chip becasue of the VAT problems. I dont understand. Heres my questions:
1. Doesn't the GEN VII ECM replace the GM ECM?
2. If no, then what does the GM ECM Control?
3. How can I have VAT Problems?, since the key has a resistor and talks to the ECM, the ECM must have a hard code which is not on the chip, however you can disable the VAT on the chip which will ignore all readings from the ECM. ( is this how it works)
If they must program the chip, how long should it take them. I was told 1 1/2 hours. I say , at the most 1/2 hour.
Please explain to me how this works and why the GEN VII would cause problems.
Brad
San Diego
Old Apr 22, 2003 | 03:03 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You can buy a VAT by pass for about $25 bucks. I think the ones for a key you just put the key in the bypass module and wire it inline. I installed remote starter in my 2001 Sonoma and had to use a bypass although mine is not a key system. I got it from www.bulldogsecurity.com.
On second thought, they don't sell direct but they can route you to the wholeseller.
**After further thought nevermind, the bypass uses a key placed inside it to send a signal to the ecm to allow the car to be started without the key in the ign but you no longer have the oem ecm to send the signal to.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
hydrolic144
Aug 29, 2015 04:14 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
