no more egr in ecm help
Old May 14, 2003 | 02:36 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
how or where exactly do i go to get the egr burned out of my ecm? do i have to take out the ecm or can i roll right into a shop and have them do it!
i'm taking out the egr along with the other emmisions stuff when I do my headers and I don't want any problems.
Old May 14, 2003 | 02:37 PM
TransAmTBI's Avatar
Engine: 305 TBI
BY the way I have a 88 305 TBI
Old May 15, 2003 | 04:03 AM
CrazyHawaiian's Avatar
Car: too many ...
From what I understand you dont NEED to do anything to the chip unless you cant stand the error code. The EGR stuff in the chip will only give you an error code, thats it. It wont affect the drivability of the car. So if the error code matters to you, then burn a new prom with the EGR sensor check turned off. Other than that, pull the sensor and weld up the holes left over and you should be good to go. Doing the same thing to my RS track car (motor is a 88 L98). I dont really care about error codes, but since I'm burning a chip anyway, I might as well turn the EGR check off. This is just what I've read. You might want to double check with others before doing anything.
Old May 15, 2003 | 09:51 AM
TransAmTBI's Avatar
Engine: 305 TBI
ok now how do you go about burning a prom???
gta892000
Aug 11, 2019 11:16 AM
thunder57
Nov 7, 2015 02:28 PM
2012sergen11
Oct 13, 2015 07:38 PM
djmarch
Oct 2, 2015 10:41 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
