that crazy ECM
Old May 16, 2003 | 03:23 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
that crazy ECM
I have 86 Z28 TPI. A while back my car caught on fire(wiring problem). I got a wiring harness from the Junkyard and ECM from some guy. Yesterday I installed the wiring and ECM and I think I conected'em right. I tried to start my car up and the engine began to rotate but did not run. My check engine light did not come on (bulb is fine) meaning my ECM is not working. I checked the power inlet at the ECM conector and it had power. Then I tried to bypass the ground and I noticed my RPM needle was going up and down about 200 rpm everytime I grounded the circut.
How do I check the ECM if it is still alive? Where is my problem?
is it
1 ecm
2 conectors
3 me :lala:
4 other
Thanks,
Ivan
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
