Converting to SDI and Smog ramifications
Old Aug 10, 2003 | 06:43 PM
P170412's Avatar
A question for people in California who have converted from MAF to SDI.
I have a 1988 IROC, originally a MAF car. Motor is modified enough that MAF is becoming problematic. I am considering an accel gen 7 piggybacked on a stock ecm which would mean I would be converting to SDI. If I switch to SDI will this raise a flag at the smog station in California?
I assume I would have to switch to a later SDI ECM so it would not be throwing codes, but would I get nailed for using SDI on a car which came with MAF? Or would they even care or know to look for that?
Old Aug 10, 2003 | 11:39 PM
FAST LiFE's Avatar
No...you won't have a problem passing smog. Had to do the swap from MAF to MAP and never had a problem with it. I have 6 other friends that did the swap for there DFI's that passed smog visual with no problem. Thats something smog technicians won't be looking for Use the factory SD TPI intake tube and you should be fine. Hope this helps...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
jamieriplilb
Exterior Parts for Sale
Oct 28, 2016 10:30 PM
racereese
Oct 10, 2015 09:39 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
