Do i have to change stock ecm with high stall tc?
Old Aug 12, 2003 | 04:52 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Ok, i have been having alot of tranny problems. This is my second "rebuilt" transmission that is doing the same thing. I installed it, started it....and 4th (OD) gear won't do nothing. I changed over from stock tc to a 2400-2600 stall. The car will pull ok in 1st, 2nd, and 3rd....feels really weak, but it seems to shift fine. Then when I put it into overdrive, i have to rev really high just to get the car to move. And it doesn't move very much. I have talked to the tranny guy and he thinks it is something with my car. Could it be the TC? ECM?
Someone please shed some light on this. I am sofa king lost. I have spent so much money & time on this stupid car. I am without transportation. HELP!
Could this be something else or is this for sure a tranny issue?
I posted this in the tranny forum too....i need help.
Old Aug 31, 2003 | 04:42 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im guessing your running a TPI b/c of your name. And you running a 700R4 more than likey b/c you sayed O/D. But correct me if im wrong b/c im not 100% sure. What eninge, trans, and year (for ECM)? What type convertor?
Old Sep 1, 2003 | 02:40 AM
Car: 1990 Iroc-Z
90 camaro irocz. 350 l98 tpi w/ "performance" 700r4.
the tc is a 2400-2600...only thing i know about it is:
its a b29x model rebuilt tc.
Old Sep 1, 2003 | 10:08 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I really dont want to lie to you and give you any wrong info but i want to help you b/c i just had to rebuilt mine b/c of someone elses stupidty. But i seriousley dont beleive its the ECM that has to do with anything b/c all it controls really is the convertor lockup.
It sounds like the 4th gear switch or the clutches are slipping when you go into overdrive b/c you have alot of strain on the trans. But i dont know for sure. Sorry i couldnt help.
Old Sep 2, 2003 | 04:08 PM
Car: 1990 Iroc-Z
hey thanx anyways. anyone else think it could be anything other than the tranny? i am about to buy another tranny, and send this scrap metal i bought from ebay back to florida. i just don't want to buy another tranny and have the same problem.
i been without a car for months now. anyone??
Old Sep 3, 2003 | 01:39 AM
idrag2's Avatar
I don't see the ECM causing it, correct me if I am wrong but doesn't the ECM just control LOCK UP? It sounds like you may have a lip seal gone bad or clutch burned. How NEW is this tranny?
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
355tpipickup
Aug 19, 2015 10:02 PM
Fronzizzle
Aug 19, 2015 01:36 PM
marcusaw
Aug 10, 2015 08:13 AM
