code 12
Old Sep 10, 2003 | 04:43 PM
jeremy178's Avatar
Car: '89 Camaro RS
code 12
I was wondering if anybody knew what to do about code 12, no reference pulses to the ECM? I have no idea what this means
Old Sep 12, 2003 | 09:33 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Code 12 is displayed when you enter and exit the diagnostic mode when you plug your code reader in or ground your aldl port to get trouble codes. The reason no reference pulse to ecm means it is not getting info from your sensors because the engine is not running.
Old Sep 15, 2003 | 01:09 AM
bigals87z28's Avatar
Car: Check The Sig
or... code 12 means that everything is A-OK. code 12 means that your fine. Your only supposed to check your codes in the ON position.
Old Sep 16, 2003 | 11:08 AM
jeremy178's Avatar
Car: '89 Camaro RS
ok thank you
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
