MAP values...
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
MAP values...
I put the scanner on my car the other day to check out how the new engine runs...Well, it runs nasty rich at idle. I haven't done any other testing or tuning yet, one thing at a time...Anyway, are a few of my readings at idle, warmed up...
INT 98
BLM 108
IAC 23
TPS .78
O2 Xcounts 5-4
Base PW 2.0
MAP 60
O2 mv 824
The thing that I find the most curious is the MAP reading. It seems that it shows me to have very little vacuum at idle. The cam I am running is mildly aggressive in my opinion and I expected more vacuum. I will hook up a vacuum guage and see what it shows tomorrow. What do you guys and gals think of this? I know I am very rich, you should see the plugs! What do some of you with more aggressive cams or similar cams see for MAP values at idle? Thanks in advance...
224/236 @.050"
.525/.555
113 LSA
Comp blower cam, no I don't have the blower yet!!
INT 98
BLM 108
IAC 23
TPS .78
O2 Xcounts 5-4
Base PW 2.0
MAP 60
O2 mv 824
224/236 @.050"
.525/.555
113 LSA
Car: check
Engine: check
Transmission: check
Re: MAP values...
Originally posted by 92 zzz28
. . .MAP 60
O2 mv 824
224/236 @.050"
.525/.555
113 LSA
. . .MAP 60
O2 mv 824
224/236 @.050"
.525/.555
113 LSA
RBob.
Car: Guess
Engine: Crazy 8
Okay, thank you...I posted the same thing on the TPI board and got only one response. He said the same thing as you. Not that I didn't believe him, I just like to get lots of opinions. Any suggestions as to what I can do to make it run leaner at idle?
I was thinking about moving the VE values from a lower KPA to the 60 KPA at the idle RPM range and see what happens. Is that a good idea?
Car: An Ol Buick
Engine: Vsick
Your on the right path.
