Threw some codes....
Old Oct 29, 2003 | 06:50 PM
Fbodynut04's Avatar
Car: '85 Z28 w/ T-Tops
Engine: 305 4 bbl....for now....
Allright, tonight i decided to check some codes.... i bridged the a & b slots, and i threw codes 23 - 24 and 45. if anybody can tell me what they are id appriciate it...maybe this will solve my speedometer not working problem.............
thanks
Old Oct 29, 2003 | 10:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Threw some codes....
thanks
23- MAT
24-VSS
45-rich
Old Oct 30, 2003 | 05:26 PM
Fbodynut04's Avatar
Ahh...Thanks a bunch... this may sound a bit dumb but what is the MAT and where is it located????? I know where the VSS is seing as how i've already replaced it once and yet no change....maybe a 2nd time.....anywhos, thanks again
Old Oct 31, 2003 | 11:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In your '87 Camaro RS 2.8 MPI it would be in the aircleaner box above the radiator on the drivers side.
RBob.
Old Nov 1, 2003 | 12:33 AM
Fbodynut04's Avatar
Any thoughts as to where it might could be on my bird???
A short time ago i took the belt off my air-pump and disconected probably half a dozen clips for emissions junk...Partially because i figured that since i smooshed my EGR return tube (gravel road intersection) it couldnt hurt much...The car actually runs better w/a few of the clips unplugged.
Thanks for the input anyways.
Jon
Old Nov 1, 2003 | 07:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Jon
I sort of skipped over the 'Bird since you had a 4bbl on it. However, if it was originally a TBI it was in the aircleaner, if TPI it was in the bottom rear of the plenum.
[edit: just checked the tech data and found out that the last year for 4bbl's was '87. If stock then I'd say air cleaner housing for the MAT, which when in an air cleaner is an IAT, still does the same thing].
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
82tabird
Dec 21, 2015 10:22 PM
92projectcamaro
Sep 29, 2015 07:07 PM
fly89gta
Aug 22, 2001 09:33 AM
