Help Need to Identify connectors for 86 camaro TPI setup
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I am working on a tpi harness out of 86 camaro The ECM number is 1227165 I have no clue what I am suppose to connect this connector to. When it is time to connect these wires into a non-fuel injected car where do I put them. Help some one Please
Please see attached photos
Thanks:hail:
Thanks:hail:
Car: check
Engine: check
Transmission: check
Re: Help Need to Identify connectors for 86 camaro TPI setup
Thanks:hail:
Thanks:hail:
Hopefully someone else recognizes them and can post to be certain.
RBob.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wires
The clear connector is what they call the 15 pin connector and it hooks all the car wires to the computer ie. battery, ign., ALDL, fuses, and fuel pump etc.
Linson
Aug 21, 2015 02:12 PM
Sanjay
Aug 12, 2015 03:41 PM
