Does the 727 ECU work for SD or do you need 730?
Car: 89 Iroc
Engine: 305TPI
I am not sure if I will get yelled at for this or not but does anyone know? Thanks.
Car: check
Engine: check
Transmission: check
Re: Does the 727 ECU work for SD or do you need 730?
The harness connectors are different between them.
Both will run the same code (mask id) in the same manner with the same functionality.
RBob.
Car: 89 Iroc
Engine: 305TPI
So when repinning them will they line up differently?
I am curious if it would be easier to just get the 730 or get the 727.
I need as much help as possible. This would be my first major project by myself. I have the article printed out and I am reading it, but it just talks about 730.
Car: check
Engine: check
Transmission: check
I'd venture to guess that you are converting from a '165? If so, then use the '730. The '727 ECM harness connectors are very different from the '730/'165 style.
RBob.
Car: check
Engine: check
Transmission: check
Originally posted by subsonic9
I have been looking for 727 connectors for a while now to no avail. 730 is the best route.
RBob.
Car: check
Engine: check
Transmission: check
I have two sets of different connectors and both are incorrect. On the "C" connector the pin hole for the data line is not there.
RBob.
Car: 86 IROC
Transmission: WC T5
I have the pin outs. I just tried a guy that says he has the right connectors. I hope they are good to go. Then I'll be making my harness, And all will be good in my world. Til my wife finds me at the shop.
Car: check
Engine: check
Transmission: check
RBob.
Car: Death Mobile
Engine: 666 c.i.
I've moved this to the DFI/ECM forum where it belongs and where the ECM expert (RBob) can give his undivided attention. I guess that's why RBob was made moderator of the DFI/ECM forum.
Along these lines,,
Does anyone have the packard/delfi part numbers for these 4 connectors and pins, or at least the pins?
How about part numbers for the other connectors in the system?
I two am wanting to build a harness from the ground up.
Thanks, Greg
Thanks, Greg
Car: Death Mobile
Engine: 666 c.i.
Originally posted by gregger2k
Along these lines,,
Thanks, Greg
Along these lines,,
Thanks, Greg
Car: 86 IROC
Transmission: WC T5
GM Parts Direct can get them to you. They are a special order item, and take about 2-3 weeks to come in. I also got 4 packs from my gm dealer.
Also takes a special crimping tool.
subsonic9
You don't happen to have the GM part numbers do you?
If not, what do you tell them what you want?
I work at an OEM and I have the special packard tools so that should not be a problem.
Tnanks, Greg
Tnanks, Greg
Car: 86 IROC
Transmission: WC T5
The gm part # for the 727 pin is 12066132. I don't have gm #s for the plugs, But I now have a supplier for the four connectors. I don't want to break any rules about advertising so e-mail me at:
steve at subsonic9 dot com
I post this this way now due to spam bots.
eightsixseven
Dec 16, 2024 01:50 PM
