Problem with OBD 1 scanner
Old Nov 11, 2003 | 02:16 PM
mikeeathome's Avatar
I am having a problem with an autoxray OBD 1 scanner. Although I can not tell if it is the scanner or the ECM computer that is at fault.
Believing the that they are both just serial data devices I attempted to "scope" the data lines and could not see data transmittion on the ECM interface connector or the scanner separately.
Does this lack of data from the ECM mean it is not operational or I am I just miss understanding the operation.
Any help or guidance appreciated.
Mike
Old Nov 11, 2003 | 05:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Problem with OBD 1 scanner
Mike
Some ECMs will send data w/o any interaction from a scanner. Others require a 10K resistor across the ALDL terminals A&B. Then others will not send a thing until requested by a scan tool. All depends upon the ECM/Mask that is involved.
RBob.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
