BCC to specific vehicle ?
Old Nov 11, 2003 | 08:10 PM
eighty8T/A's Avatar
well the BCC code from my car is akxy-3287. my car is an 88 T/A 5.7l auto. this site (http://www.gmpcm.com/filedb/pafiledb...on=file&id=603) says its for MPI. which is right? my assumtion or the site? if it is 4 MPI would it run my TPI?
thanks
Shawn
Old Nov 12, 2003 | 12:26 AM
Mechanic's Avatar
Multi-Port Fuel Injection (MFI) is a fairly broad term. In this instance it indicates that it is not an electronic carb, throttle body injected (TBI), or sequential fuel injected (SFI) application.
Tuned Port Injection is just another term used when referring to a Multi Port Injection system that happens to include an indication of its intake manifold runner design.
Please also note that the binary file information available on our site is based on official GM specifications, so we are pretty sure that the information would carry a bit more weight than an assumption.
Old Nov 12, 2003 | 07:30 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
A 88 MPI 5.7L in an F-body would be a TPI. Looking at what it says there, that's what it is for. Even Further into it, a L98 is a TPI engine.... So it SHOULD run your car, but how well is the question.....
As already stated, TPI is a form of MPI. MPI means basically each cylinder gets it's own injector, as opposed to TBI which in a stock app. gets one injector per bank.
Old Nov 12, 2003 | 08:50 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I've redirected this post to the DFI/ECM forum.
Old Nov 12, 2003 | 10:53 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I show the following for AKXY
1227165 ECM
$32b Program Code Byte
1988 Firebird/Camaro
350ci L98
4-Speed Automatic
3.27 Ratio
Federal Emissions
Theft Deterrent System
Good luck.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
MrPackstin
Oct 25, 2017 08:09 PM
Vintageracer
Sep 24, 2017 12:34 PM
Gordonr1973
Sep 29, 2015 11:59 AM
wstephan96
Sep 25, 2015 04:28 PM
