Lv8
Old Nov 15, 2003 | 03:39 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Lv8
165 ECM AJUL bin
Load variable; (air flow/rpm) * k constant=load
is air flow in gm/sec (mass,) or ft^3/min (volumetric flow)?
Is the K constant for coolant temp in kelvin, if its just a multiplier want is it's value?
Old Nov 15, 2003 | 10:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Lv8
Originally posted by rgarcia63
165 ECM AJUL bin
Air flow is in mass, grams per second. The temperature of the air is included in the mass flow measurement.
RBob.
Old Nov 15, 2003 | 06:01 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
LV8
Reply from: RBob
And engine speed is in RPM, that leaves the K constant, which is what I really wanted to know.
Old Nov 15, 2003 | 07:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: LV8
Hmm, OK, if I may ask, where are you seeing the equation that references/includes K?
RBob.
Old Nov 16, 2003 | 02:31 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
K constant
I found the reference in a Buick Regal Turbo link user's manual, yes I know my engine isn't boosted, and it isn't a Buick.
Excerpts from webpage:
1) "LV8 is calculated from many factors and is used in
determining engine opeating parameters"
2) "It is calculated from (air flow / engine speed) * K where K is a
constant."
I looked at this because I couldn't find it in any of the GM 1227165 ECM's documentation, or web searches, but in trying to find the webpage where I found the above formula, I also ran across the formula for the 165' ECM which has no multiplier "K" just (air flow / engine speed) as you had said.
My method of understanding is by doing the calculation myself and I can't calculate the airflow using the (air flow / engine speed)=load formula.
Rewriting formula to solve for flow (air flow=load * engine speed.) doesn't give an acceptable value for gm/sec.
What I missing, and or doing wrong?
Old Nov 16, 2003 | 08:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Understood. The K is a constant that is a calibration term. In the BUA (a $32 mask bin) it is at location $C69A, right before the MAF scalar tables. Here is the location, commments and stuff:
Code:
LC69A:	FCB	80	; Ld VAR FOR SCALING LV8 SCALE FACTORS
		   	; CAL = arg + 64, (16)
It isn't easy to just plug the numbers into a calculator and get an answer. There is all kinds of scaling going on in the code. If it helps the following is a moderately commented section of the code that does the conversion from gms/sec, RPM, and K to LV8.
RBob.
Code:
; Calculate the LV8 term
; BUA
	LDX	L0095		; Current Minor LP Ref Period
	BRSET	L0034,$80,LD77B	; BR IF b7, engine RUNNING flag
	CPX	LC357		; Crank RPM lmt
	BCS	LD77B		;
	LDX	LC357		; Mult'cnd to X, (Crk RPM lmt
; Go do 16 * 16 Mult
LD77B:	LDD	L00EA		; Gms/Sec Disp Value, (Mult'plr)
	JSR	LF2F0		; 16 * 16 Mult routine
	PSHB			; Save Middle 2 Bytes of Product
	PSHA			; Save Middle 2 Bytes of Product
; create one & two delayed LV8's
	LDAA	L0063		; FILTERED LD VALUE (LV8)
	LDAB	L0061		; one delayed LV8 (for two delayed term)
	STD	L0061		; L0061 is one delayed, L0062 is two delayed LV8
; mult result if above calc by scalar term
	TSX			; point to middle 2 bytes of prev calc
	LDAA	LC69A		; Ld VAR FOR SCALING LV8 Scale factors
				; 80d = 80/64 = 16
	JSR	LF472		; FACTOR IN 8x16 MULT
	LDD	0,X		; get result of 8x16 mult
	ROLB			;
	ROLA			;
	BCC	LD798		;
	LDD	#$FFFF		;
LD798:	ASLB			;
	ADCA	#0		; ROUND
	PULX			; stack clean up
	BCC	LD7A0		; bra if no ovf of adca
	LDAA	#255		; USE MAX VAL
LD7A0:	STAA	L0063		; FILTERED(?) LD VALUE (LV8)
Old Nov 17, 2003 | 12:42 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
LV8
Thanks, Bob.
Old Sep 7, 2004 | 09:48 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Hi, bringing this back from the dead for some info.
Rbob, can you please explain in more detail what is happening with this snippet of code for calculating LV8? I'm trying to decipher the assembly, but its losing me pretty quickly.
This is for general tuning doc for 32B, MAF, to show how LV8 is calculated, something I wanted to put together along with what a few others are doing, in this threard in the DIY PROM section:
https://www.thirdgen.org/techbb2/sho...hreadid=257513
thanks!
Doward
Dec 7, 2004 10:35 PM
wjbecker
Mar 13, 2004 06:21 PM
funstick
16
Jun 18, 2003 07:18 PM
Sena'sIROC
Aug 12, 2002 10:06 PM
