Tuning the pump shot (understanding Acceleration Enrichment Factor vs. Change LV8)
Old Sep 29, 2003 | 09:46 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I want to try to change the Acceleration Enrichment Factor vs. Change LV8 table in my APYP bin to help with a very, very bad WOT bog that I have. 350 TPI, 214/224 .442/.465 112lsa flat tappet 10:1 compression, 461 heads, blah blah blah. The car has run a best of 14.3 in hot weather, but has an absolutely horrendous throttle response. Every time I shift (5 speed) it is absolutely gutless in the next gear. My 305 GTA throws me into the seat when I shift, and my 91 Vette throws me HARD into the seat when I shift. There's no reason why my IROC should be so gutless after shifts. I also smell gas at WOT, and I think it's all related.
Anyway... I want to lean out my pump shot, but I'm really not understanding the Acceleration Enrichment Factor vs. Change LV8 table too well. What exactly are the LV8 counts, and how do the 5 fields in the table effect the car? I want to understand what I need to be changing in order to lean out my pump shot. Thanks.
Old Sep 30, 2003 | 06:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
If I understand you correctly,
The 5 fields are for the increments of how much change there is in LV8. ie larger changes getting more AE then smaller ones.
Easiest thing to do is make a small change and then go out and drive the car. Make changes just in one area, at a time, and get familiar with what each area's changes feel like. Yep, takes time, and experimenting to get the feel down in some of this.
Old Sep 30, 2003 | 11:05 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
https://www.thirdgen.org/techbb2/sho...ght=enrichment
Old Oct 2, 2003 | 11:50 AM
Jim85IROC's Avatar
Thanks for the help. Hopefully this weekend I'll have time to burn a couple and start playing around with it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
